Likes_to_tow
Mar 23, 2017Nomad
Why do Class C's always leak in the front upper bunk area?
Came close to buying a new Class C late last year but instead purchased another 5th wheel. Not so much because of their tendency to leak in the front overcab area but there was some other things that made us stick to another 5th wheel. Maybe sometime in future we will get a small c.
My friend found an unbelievable deal on a used 2011 with only 3800 miles on the clock and wanted me to go look at it with him. It was in unbelievable condition for a 2011!! It had been stored under a roof mostly out of sunlight and rain. I could find nothing anywhere from top to bottom that looked questionable until I looked under the mattress in the over the cab bed. There were water stains on each end of the mattress on the bottom side. Close examination on the outside revealed water oozing out from the edge trim molding when you pushed on it. A classic example of lack of proper maintenance sealing. The owner was really shaken up by our findings and had no idea Class C's are famous for this. Now he was faced with a huge repair bill before he could sell it unless some poor unsuspecting buyer did not look under the mattress. I've notice a major change in some higher end models where the front cap is all solid fiberglass and actually wraps around the side a few inches. Looks like this would be much better than just having a piece of molding on the edges. At any rate, if you
are in the market for a used C I suggest you pull the cab over mattress and check for stains!!
