Snomas wrote:
I was wondering if anyone has had there tire pressure monitors not give PSI readings if there is another wireless device nearby? I sent back a TPMS system because the monitor would only read the PSI on one or 2 tires and the rest of them were blank.
As more and more of our world goes wireless this is going to become a growing problem, however,, Generally no.
I have seen false readings, and no/readings, but the circumstances suggested that the cause was a passing vehicle with the same system and there are only so many ESNs, so I'm guessing the passing vehicle had a monitor with the same ESN (Electronic Serial Number) send a packet to my receiver.
On the other hand I have had a legit alarm tell me that I'd been screwed,, So I added air, kept adding air till I got to the tire store, where they removed the screw and put in a proper patch, So then I'd been "Booted". Total cost, around 25-50 cents in gasoline and about an hour's time.. Not bad.. Another customer of the same company i bought from failed to install his right away.> Same tire, over 2,000 in secondary damage PLUS tire and rim.
