Dutch_12078
Jun 24, 2015Explorer III
dons2346 wrote:holstein13 wrote:egh33 wrote:This is probably the correct answer -- along with using a standard windshield for good parts availability and ease of replacement.
If the window shield was not real big they would have no way to get the refrigerator in and out.
A big windshield is not needed to R&R a refer. A side window can be removed much easier which is what my installer did. You do have to remove the doors but they will fit through a window
My Norcold fridge is 24" deep, and my entry door is 26" wide, so no problem removing it here without taking anything apart. I'll have to check the dimensions on a residential fridge though, if I decide to go that route should this one fail.
38,777 PostsLatest Activity: May 24, 2026
