burlmart
Sep 07, 2016Explorer
not waging any battle, but i recall old ads where bornfree described how they carefully tested each new unit in a 'rain chamber.' this sure admits to a low certainty in a modern fiberglass advanced roof system.
IIRC, bornfree - long considered to be quality - used a fiberglass roof on rv.netter skidrowjoe's rig, which he often said leaked a lot and the factory couldn't fix it.
nexus says: "The seamless fiberglass sidewalls and fiberglass roof, plus molded front and end caps, reduce the possibility of leaks from water intrusion." no mention of unique sealant detailing at openings and along edges. note that just as BF showed uncertainty in their roofs thru rain tests, nexus is also aware of "the possibility of leaks from water intrusion."
38,781 PostsLatest Activity: Aug 12, 2026
