supercub wrote:
I have an Onan 7500 diesel generator. With a Xantrax 2000 watt inverter/charger. It cycles every couple of minute. I've let it run for a couple hours, batteries are charged, so I'm assuming it's the charger that is cycling. I wasn't aware while charging the charger would cycle, why is that?
Because you are using 12v's somewhere (lights, CO detector, radio memory). You're water heater will turn on and off too, as needed, causing the genset to rev every so often. If it bothers you, put a constant load on it like so many have said.
