Desert Captain wrote:
OK Don, I have to respond as you are playing a little fast and loose with the facts... :B
You have to get it to fit securely (and that opening is not going to match up in most cases), and bring clean AC power to it. Don't forget to secure the doors and be sure it has adequate ventilation.
We do agree it is not the ideal way to boondock. As I noted RV's are designed to minimize the use of AC power and other than the air conditioning and microwave nothing draws as much as a residential frig.
Good afternoon
In my experience after doing three conversions including my own fitting and trimming in is simple with a miter box and saw and properly stained wood to match. Simple may be a relative term but I am not a carpenter or craftsman. Clean AC power is as simple as an inverter which many larger coaches already have. Most also have four batteries which are adequate although bigger and more is better. As I mentioned, a robust solar system should be considered part of any residential install for those who intend to dry camp. A robust solar system more than provides all the power required by a residential fridge and if the sun gods are shining, a surplus. Securing the doors, a 12 inch piece of velcro. We are full timers so our entertainment centres draw more than our residential fridge by a long shot. Overall if I factor in good and bad weather I would say that we run our genny about 15 to 30 minutes more per day than before our residential. We have always run our genny every day during breakfast prep and sometimes during supper prep. It is a 7.5 quiet diesel, no one cares and for the most part those with RV fridges and no solar run their genny considerably more than us. On days with full sun we run our genny no more than we use to before the residential.
I would agree that smaller rigs with room for only a single solar panel or two and one or two batteries would be less than prime candidates for a residential. For those rigs something like a sunfrost fridge would be a better choice or something with a dann foss compressor.
JMHO.
