- jorbill2orExplorer III've used this This and it's worked great for me watch the video and it will explain better than I can
- usersmanualExplorer
wolfe10 wrote:
I have used this very successfully for the last decade on the sailboat and in the motorhome to boost weak WiFi signals:
http://wavewifi.com/products/rogue-wave/
I don't think you can boost a wifi signal? would it not have to be the actual source that sets the signal strength?
I know little about such but understood theses device just are able to pick up a signal from a greater distance than your situated in
???? - wolfe10ExplorerI have used this very successfully for the last decade on the sailboat and in the motorhome to boost weak WiFi signals:
http://wavewifi.com/products/rogue-wave/ - usersmanualExplorer
RLS7201 wrote:
Guarantee this will work, but may be more than you want.
Richard
yes same as I posted earlier today
Does anyone know if this is that much better its 3 times the money
http://wifiranger.com/shop/product/53-mini-pack
Or this one at 7 times cheaper?
http://www.technorv.com/Alfa_High_Power_Desktop_WiFi_Antenna_p/wifi-desktop-nh.htm?Click=8042 - Joe_RochelleExplorerCheck out Wifiranger.com They have products that do just this. There is an external antenna that mounts on your RV. A good rule of thumb is the higher the better for these things. Also, there are some blogs that cover this. Another product is presented by "We're the Russos" http://weretherussos.com/extend-wifi-range-wifi-booster-repeater/
joe - RLS7201Explorer II
- lakebumExplorer
Second Chance wrote:
You may need to look at an antenna/amplifier setup. Personally, I would not spend any money to pick up an unsecured campground wi-fi network - it's just not worth the risk from a security point of view.
Rob
Most public WiFi networks separate all traffic via a VLAN, that way nobody sees anybody. Have setup up a few public Wifi networks and security has never been an issue.
As far as the OP, the problem is your RV reflects the signal, so you do not so much need an amplifier, but an antenna on the outside to pickup the signal and bring it inside. Depending on what you use on the inside would determine what you need. - ChooChooMan74ExplorerGood luck!! WiFi at parks sucks. Too many people using what little bandwidth they have. I do have a setup on my trailer, but it is pretty complicated for most people. I have a WiFi transceiver on the roof, that passes the data down to a mini router in the camper, that is just powerful enough to use around the camper.
Gone fishing wrote:
Can anyone recommend and wi-fi antenna that will pull in the signal in a camp ground. I have tried and Alfa marine antenna and that did not work at all.
Thanks, Bob
remember it also depends on how far from the hotspot you are and the signal strength their transmitting and number of people all on at the same time!!
here is a interesting link on what u asked just copy and paste
http://www.outsideourbubble.com/secure-private-rv-wi-fi-and-making-a-better-park-connection-for-under-100 - Second_ChanceExplorer IIYou may need to look at an antenna/amplifier setup. Personally, I would not spend any money to pick up an unsecured campground wi-fi network - it's just not worth the risk from a security point of view.
Rob
38,766 PostsLatest Activity: Jan 10, 2026
