Executive wrote:
I use the Wilson 801245 amplifier with an external antenna. There are two antennas available and I've had success with both.
The first is an 18" magnet mount that I simply attach to a cookie sheet and lay on the ground under the motor, then run the cable thru the engine compartment into the bedroom. The other is a trucker antenna, Wilson 301133, which I mount to a 10' piece of PVC which I attach with bungees to the ladder on the rear of the coach. The cable is run the same as the 18" one.
Inside the coach I have a PremierTek ANT-P8025 attached to the amplifier and I use my phone as the hotspot....hope this helps.....Dennis
Dennis:
If I understand you correctly, you use three different antennas: on the ladder, under the motor and inside the coach. Are they used together or are there certain conditions for which you use one antenna over the others? Forgive me if it sounds like a silly question, but I am a newbie to the mobile WiFi technology.
Thanks,
