dshinnick's avatar
dshinnick
Wierd bathroom water problem
Hey all-
It's a 2015 Itasca Sunstar, aka Winnebago Vista.
The flow of COLD water to our bathroom, the water closet, has gone down to almost nothing, perhaps 1/4 of its normal flow. Here are the facts:
- The slow flow appears at the toilet and in the sink, both in the same "closet".
- The HOT water in the sink, right next to the toilet, appears normal.
- The shower, directly opposite on the other side of the coach, seems normal, both hot and cold.
- The kitchen sink seems normal, hot and cold.
- Water pressure from the park is normal.
- Turning on the pump had no effect; cold water in toilet room still slow.
- This just started this morning. Outside temps are in the high 50's.
So it would seem that the cold water line, common to the toilet and toilet-room-sink has become clogged or restricted somehow? Not sure what else could account for this.
I may have to call a pro on this unless someone here has an idea. Any thoughts?
Thanks in advance-
Dave
  • I wonder if a pipe folded over on itself in a tight turn womewhere? Other thoughts are good. Just what I had dealt with a qhile back. Please let us know what you8 find
  • Low flow in our toilet is our first clue that it's time to change our water filter.
  • The problem with mineral build up is how it seems to suddenly happen. Since Lavy Hot water flow is normal, that points to the calcium chunk in the cold water inlet valve of the Lavy faucet. NOT the exit strainer since the hot water is normal. You need to pull the Cold water valve body of the lavy faucet. You need to pull the water line off the input of the toilet. You will probably have to pull the toilet and look at the water valve inlet of the toilet. It probably has Mineral build up. You either pull the toilet water valve and rinse it out or just replace the toilet water valve. PRESSURE is not your problem. FLOW is. Doug
  • Update:
    The toilet has an attached hose and a small hand-held sprayer. With nothing else on, the sprayer produces no water. But when I hold down the toilet flush pedal, the handheld releases a full-strength spray, and the toilet continues its poor flow. When I release the toilet flush pedal, the handheld stops, and the poor toilet flow continues.
    Not a solution, but interesting. Seems to show that the water pressure to the toilet is ok.
    Suggestions have included checking filters and water valves, but:
    - I can't imagine two completely separate filters becoming clogged overnight. Not gradually, but suddenly.
    - If valves had gotten turned, wouldn't I seem some leakage/draining of some type under the coach? Nothing.
    Thanks.
  • Have you double checked the cold water drain valves leading to the bathroom?
  • Water sources at CG's are notorious for having a lot of sediment in them as often they are wells. The screens at faucets get pretty clogged up as do the screens on the water pumps. Try cleaning those out.
  • I found a lot of debris in my water lines on the RV. Just disconnect one end of the cold water line and let it pump in to a container until the flow picks up. You also need to clean the filter screens at the end of each faucet on a regular basis to remove the debris particles.
  • Just a wild guess, but is it possible one of the winterizing valves or water heater bypass valve(s) got moved?
    I believe Winnebago has all the plumbing diagrams on their website, so I'd recommend you check them out to see exactly what might be causing the issue.
    ~Rick
