j-d
Aug 17, 2013Explorer II
Be sure to look at specs on any of them. You want a good Net Carrying Capacity, and a decently long wheelbase. I'd guess that a "31-footer" (usually longer or shorter than 31) should be around 220-inch wheelbase. If not, the rear axle will be overloaded and not enough weight on the front for good highway tracking. Slides add weight, so if there's a slide room behind the axle, then I'd suggest paying special attention to the WB.
