rgatijnet1
Nov 23, 2019Explorer III
Most Class A's have 120 volts available, even at the side of the road. This makes it easier to find a compressor that is large enough to quickly inflate a large tire. Most 12 volt compressors will take a long time to fill a large tire to 95+ psi.
Harbor Freight has two different 120 volt 3 gallon tank air compressors on sale this month for $39.00 each. One is a 3 gallon pancake type tank and the other is a 3 gallon sausage type tank compressor. If you have 120 volts available, or if you only plan on using it when parked or with a generator, you can't beat the price and either one would probably take care of your needs on an occasional basis.
38,769 PostsLatest Activity: Apr 03, 2026
