Mr_Mark1
Dec 30, 2014Explorer
If you are not winterized, fill your fresh water tank as it would take quite sometime for that much water to freeze. Only use water from that tank and leave your hose stored. Only dump the black tank when needed.
Twenty six degrees is not that bad and shouldn't freeze anything for just one night. If you find that you don't have a heating duct in the basement, connect a drop light in the bay to keep that area warm.
Good luck,
MM.
Good luck,
MM.
38,782 PostsLatest Activity: Sep 02, 2026
