rgatijnet1
Dec 30, 2014Explorer III
We have used a 100 watt light bulb in our wet compartment for temps down approaching zero. Right now we are in Maryland and expecting temps down to 28 tonight. For the time that the temp will be that low, we won't even need the bulb in the wet compartment. As long as you are using your water, have the fresh water tank full, and do not hook up a hose to shore water, you should not have a problem with temps down to 26.
38,782 PostsLatest Activity: Sep 02, 2026
