Johno02
Dec 30, 2014Explorer
Last month in Branson, temps down into the low teens several nights. 75 watt light bulbs in clamp-on fixtures to keep bulbs from touching in each wet bin. remote thermometer in each bin. Outside water line had heat tape and insulation. Lowest temperature in either bin was 40 degrees, with outside down below 20. Other than what you see in the bins, most fresh water pipes are inside living space of coach. As some are near outside walls inside kitchen and bath cabinets, leave cabinet doors open overnight. If inside coach is comfortable, nothing will freeze.
38,782 PostsLatest Activity: Sep 02, 2026
