jspringator's avatar
jspringator
Will regular epoxy hold?
The prior owner removed most of the carpet in my 27' Sightseer. He replaced it with thick tile that was secured with some sort of adhesive. The adhesive under the accelerator pedal must be over the exhaust manifold, because the adhesive melts after all day driving, and my foot pressure is causing the tiles to move. I've removed the affected tiles and cleaned them with lacquer thinner. I'll get to cleaning the floor later on today.
My question is whether regular epoxy work for securing the tiles. I can't imagine the floor will get to 350 degrees, the upper temperature for epoxy, but I can't know for sure.
What do you think?
