way2roll wrote:
garyemunson wrote:
A lot of Classs A wind noise comes from the window frame drain holes under the fixed piece of glass on the front side windows. The drain holes under the sliding section are more than sufficient to prevent water building up and leaking in (and water can't come in under the fixed glass). The holes may or may not have useless little plastic "awnings" over them. If so, pull the ones off the holes under the fixed glass and cover the holes with black electrical tape. Big difference in wind noise.
Are you suggesting removing weep hole covers and taping the holes closed? If so, this is bad advice. I did that once and ended up with wet interior walls after a rain storm. There is a reason those weep holes are there and it's to keep water from overfilling the window channel and running down the inside.
Spot on. First, determine if your windows are Atwood, Hehr or some other brand. Then you can shop and replace them. They run anywhere from a buck to about $3/ea. depending on where you buy them. Use the link provided above to post your picture, but check to see if and how many weep hole covers are missing.......Dennis
