I have a 1999 Georgie Boy Pursuit. There is a water leak coming in at the top of the passenger side window. I took off the inside window frame and observed water seeping in and eventually running alon...
when you take out the window look to make sure it is the window that is leaking and not the roof somewhere. the roof might be leaking in the rear and working it's way to the window. the leak may not be right at the window or right above the window at the roof level.
