chrisdug
Nov 27, 2016Explorer
Ok. Fleetwood is unable or unwilling to provide information regarding my overhead window seal. I pulled the window and sent them a pic of the tag plucked build info for my coach and got nothing.
Window is leaking between the glass and the rubber channel seal between glass and frame. I can't get correct rubber from fleetwood, and I would need to pull the window apart to measure the rubber channel to get it from a third party.
Fleetwood would quote a replacement windows - at 800.00! Seems too high for a single pane fixed glass window.
Who have you purchased replacement windows from that were good quality and reasonable in price?
I will need to pull the window again to measure the opening. It looks like it was cut 1 - 1.5" too big as there is much space around the frame. Fortunately there is no water damage or leaks showing from around the perimeter. Only around the glass. I did a complete resealing of the rest of the coach and this appears to be my last leak.
Any help or direction would be appreciated!
Thanks,
Doug
Thanks,
Doug
