chrisdug
Jan 07, 2017Explorer
OK, Time to update this ongoing saga...
Pulled window again and got full measurements. Contacted Duncan RV Parts in Elkhart IN, and also Pelland Ent looking for a replacement.
Sue at Duncan was helpful, but could not find a replacement. She got hold of Fleetwood and they said the window is obsolete, and they have no replacement (Thanks SOOOO much, Fleetwood).
Pelland can make a new window for me, but they quoted a corner radius that is larger than what my current window is - I am afraid that there would be no seal in the corners as I only have about 1/4 to 1/8" overlap with the factory window.
Here are my window and cutout measurements:
Cutout in RV wall:
65.875" wide x 13.00" tall.
The wall thickness is 1.75" all around
The radius cut into the RV look to be 2.5" at all 4 corners
The frame on the window measures (where it fits into the cutout):
65.38" wide x 12.50" tall
The window frame where it mates with the cutout has 3.0" corner radius at all 4 corners
The outside window flange measures:
67.00" x 14.25" (the radius at the outside of the flange looks like 4.00")
The inside window flange measures:
66.94" x 14.12"
Note: the cutout has a smaller corner radius than the window which gives a very small overlap on the outer fascia at the corners. This looks like a potential future leak point as all four corners have only .25" max to .12" min overlap to seal with. Please advise if you think this can be improved on? (Again - Thanks SOOOO mush Fleetwood for the Quality and Workmanship. I am VERY impressed)
Pelland also quoted me about $900 by the time it was shipped to me.
I still need a window - who else can quote me a replacement? I have tried and struck out at the local RV Stealership for Fleetwood - They have not been able to produce a replacement either.
Pelland appears to be a professional company and responded promptly - they just can't make a smaller corner radius than 3.19", and the price with shipping at $900+, and 6-8 weeks to deliver is tough. I have a trip planned for late march and need this done before leaving.
There must be other professionals in the RV window business - I am hoping that all of you can provide a couple of additional contacts?
Sorry for the novel,
Doug
Cutout in RV wall:
66.94" x 14.12"
Doug
38,782 PostsLatest Activity: Sep 19, 2026
