chrisdug
Mar 09, 2017Explorer
I just thought I would post up the resolution to this problem. Jeff at MotionWindows.com gave me a really good quote (about 50% of others I received). I purchased the window and it looks really good. Window is sealed to the frame with mastic like your car windshield is.
Window was at the correct size per the order - I had to sand out the corners to clear a tiny bit and got it in and sealed. He provides double stick closed cell foam to bind the frame to the coach, and thhen you seal around the perimeter to finish the job.
I used ProFlexRV clear flexible sealant and it worked great so far. No more leaks up front - makes me Happy!
I would recommend this company to anyone looking for a replacement window. They also packed it really well for shipment and it arrived intact. They are located in Vancouver Wa.
Thanks all for your input - I hope this thread helps someone else with a leaking window. It is so hard to find good vendors to work with you. Fleetwood was completely useless as were local rv sales offices. If you have an older RV - you are totally on your own...
Thanks All!
Doug
Thanks All!
Doug
38,782 PostsLatest Activity: Sep 19, 2026
