chrisdug's avatar
chrisdug
Window Replacement - looking for source or advice
Hi,
I have a leaking window - the front on my overhead. It is leaking between the glass and the frame so I believe a replacement is needed. Can anyone recommend a Southern Calif supplier that could find me the correct window that I can install? I would also entertain having it replaced but only by someone experienced with RV construction and sealing methods.
My coach is a 2002 Jamboree 31W GT. Overall coach is in great shape, but I need to nip this in the bud - I have chased water damage before on other coaches and don't want to replay that.
Thanks for any input!
Doug
  • Since it's leaking between the glass and the frame, you should be able to have the glass reset in the frame rather than replacing the whole window. An RV repair place should be able to do that. (A glass store probably also could, but many of them are not too well versed in RV window construction and in any case would likely not have the necessary scaffolding etc. set up to perform the work and so would have to charge more.)
