Our MH has started leaking at the bottom of the front side window. I have tried sealing it with eternabond but I guess I need to reseal the windows. What is the best sealant to use on these? These are...
There are sealant gaskets between the window and body of the motorhome that could need replacement. Our motorhome only has external sealant on the top and down the sides about 1/3 way down. Stop in at any glass shop and ask them what type of sealant you should use, I'm sure they would be willing to share that information with you.
