ottersea
13 years agoExplorer
window sealant
Our MH has started leaking at the bottom of the front side window. I have tried sealing it with eternabond but I guess I need to reseal the windows. What is the best sealant to use on these? These are...
DSDP Don wrote:
...Once you're done, get some pure silicone (clear) in a tube and run a bead along the top of the window and down both sides about 6". Make sure the surface is clean.
