ottersea
May 07, 2013Explorer
window sealant
Our MH has started leaking at the bottom of the front side window. I have tried sealing it with eternabond but I guess I need to reseal the windows. What is the best sealant to use on these? These are...
Hank MI wrote:DSDP Don wrote:
...Once you're done, get some pure silicone (clear) in a tube and run a bead along the top of the window and down both sides about 6". Make sure the surface is clean.
DAP makes a clear sealant, not a silicone. I removed most of the windows in our previous motorhome. They had a rubber seal between the frame and wall so I didn't need any messy caulk. I used the DAP sealant when I reinstalled them. The dap sealant stays clear and clean much longer than clear silicone which tends to turn yellow/tan as mold grows in it. Just a suggestion.
