Executive wrote:
So, now when you level the coach, instead of the windshield popping out, it'll simply break...
IMHO, your 'fix' is only temporary. Something's wrong with how you're leveling. Stabilizing your coach should not cause the frame to flex that much....Dennis
I think Dennis nailed it -- the issue is the fact that the Coach is not being leveled evenly, thus causing the flex in the chassis and pushing the window out. The fix will last until the window breaks. So while the $5.00 fix is a good TEMPORARY fix, until you correct the leveling issue, you will continue to have problems/stress. The next fix will be $500+ to replace the broken window.
Travel Supreme had this problem and there fix was a $3,500 number of welded cross members as, the leveling system would over flex on extremely un-level sites.
JMHO,
