rgatijnet1
Apr 15, 2015Explorer III
Check underneath your coach and see if you have any broken welds, or steel braces, where the front cap support frame is attached to the chassis frame. Sometimes the steel can crack or a weld fail and cause the front cap to bounce around, which causes problems with your windshield.
If any broken welds or steel is found, any welding shop can probably make the repairs for a lot less than $5000.
I had a few steel braces on my Monaco coach and it took me only a couple of hours to weld in new steel gussets to beef up the frame.
Some of todays highways can beat up a coach with all of the pot holes.
