mccsix
Apr 15, 2015Explorer
I understand the retro fix is X bracing the frame(s) in the bays, espec mid to frt area. Can be done just about anywhere once you ID the specs. MAny repair facilities in/around Elkhart In do the fix and can probably give you the specs and an estimate.
Beside X framing, Country Coach, now Entegra put a heavy U shaped collar off the frame across the top to stop windshield popping out etc.
