vjstangelo
Nov 04, 2019Explorer
I wanted to sent out an update.
My insurance company settled and cut me a check to repair the windshield. I decided to use RV Glass Solutions as recommended by others. The shop doing the actual work is All Clear Glass out of Danville, VA.
It turns out every cloud has a silver lining. Upon removing the windshield All Clear identified extensive rust on the frame below the existing glass adhesive. There was no leaking but I'm sure that had this situation remained unidentified it would have resulted in big problems down the line.
Further, I was aware that old Winnebago Class A's had this problem, but thought they had fixed this problem with newer units (mine is a 2012). Wrong.
Anyway, the vendor wire brushed away the rust and applied a rust inhibitor which will hopefully slow down the process.
38,782 PostsLatest Activity: Sep 10, 2026
