Twomed
Dec 28, 2014Explorer
Welcome to the forum... :) :)
Chassis is more likely a Monaco Roadmaster, but we need to know the year of your RV to be sure. Suggest that you put that info in your signature or profile and you will get more specific answers in the future. Very few if any on a FL chassis. The switch is most likely a Cole Hersee as used in the big trucks.
That is a huge voltage drop...if you Google Windsor headlight relays, again depending on year you may find an illuminating :) answer. Lots of folks have wired in a separate relay to avoid the hot switch and voltage drop, the search will provide the answer to that issue for sure.
