Bill_Satellite
Aug 25, 2019Explorer II
The receiver model is important. It is also likely set wrong in the Satellite Setup routine if you use it with a home antenna and move it to the RV. You will need to check the setup routine to ensure the receiver is set to 18" round antenna and the switch type is Multiswitch and NOT SWM.
