Dutch_12078
May 09, 2017Explorer III
If your RM-DM installation is like most, the coax is routed from the LNB at the dish down through the roof at a cable entry cover that's held in place with several screws and coated with sealer. It's a bit of work, but removing the screws and clearing away the sealer to lift the cover should allow you to run a new coax from the dish to the receiver in one piece. Adding any splices in between will degrade the signal a few dB for each one.
