Bill_T's avatar
Bill_T
Wingard RM-DM46 & Directv H-21
I just about have the bugs worked out of my first installation. The remaining concern is the lack of any sound when in the signal search mode. I have been able to get good numbers on the 32 transponders. I have normal sound from the channels. But when doing the signal search there is no sound at all, it is suppose to beep beep like the Dish systems isn't it?
I have the above equipment connected via HDMI to a Jensen tv which is connected to a Jensen radio,dvd player.
Thanks for any suggestions.
  • I have the same roof mounted/manually operated antenna. To tweak the aim of the antenna to get the best signal, I watch the signal strength meter on the TV as I adjust the azimuth and elevation. No need for sound, as the TV screen is right in front of me.
  • The receivers don't beep any longer. It's a DirecTV issue and no one you can do anything about. You can install a separate signal meter or you are going to have to watch, or have someone watch, the screen.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
