CEDNH's avatar
CEDNH
Winnabago Slide Lock Problem
I have a 2012 Winnabago Sightseer 33c, the drivers side slide lock won't work, I have called Winni customer service, and the were no help and done a search on this forum and Winni Owners forum, with no luck.
I did get it to work for a while by fooling with the little flippers (limit switches?) on either side of the screw shaft. I thought maybe the shaft was bound up but I can wiggle it. The is power to the motor. Any help would be greatly welcomed
  • We had ours break twice when the RV was brand new. They appear too fragile; so we don't use them. No problems 46,000 miles.
  • Just a guess, but have you tried moving the slide shaft using the manual method of extending and retracting the slide. Maybe the locking levers have come loose on the motors.
