Up_DownDeCoast
Feb 10, 2022Explorer
Up&DownDeCoast wrote:
These were built on the Workhorse UFO Chassis with a gas or diesel engine. There are not a lot of them around. Most were built with a Cummins diesel. Not a lot of gassers were ever made. Most probably due to the 2008 recession which ran many manufacturers out of business and shrunk the model line ups of the remaining builders of the time. Replacement parts for this chassis may be very hard to find. Not to mention finding someone experienced to make repairs.
If your primary concern is the noise from the front mounted engine, there is no comparison between a 70's era front engine gasser and one built beyond 2000. They are much quieter the the older models. Yes, still louder than a pusher but my wife and I can talk at a normal voice level while cruising down the road.
I should note that the diesel model was actually on a Freightliner Chassis. The gasser was a Workhorse. Both were very similar in design and structure.
38,782 PostsLatest Activity: Sep 10, 2026
