pickerel_cove
12 years agoExplorer
Winnebago ERA Bedding Solutions?
Today I tried to imagine a solution to this ergonomic problem - In the 2010 Winnebago ERA (and I suspect later models as well), when the bed is down there are a few trouble spots for people with neck/back/spine concerns. There is a minor dip between the place that you'd put your head and your shoulders; another spot between the back and seat that is just at the right height to cause an elbow to get wedged into it when turning over; and then the spot where flexible seat meets rigid table section. We are both young and in good physical condition but need to watch out for back and neck issues especially if we intend to have prolonged trips.
We tried various items such as a queen-sized feather bed running across the bed starting where the back section meets the seat. It's an improvement but bulky for travel and doesn't address the seat back/head neck concerns. We tried a piece of twin-sized memory foam also running across the seat but still had the head/neck area to deal with.
We've considered a custom memory foam topper but tested the twin-sized piece running the length of the bed and it's easy to see that our body is still sinking into those low areas and then up again when it hits the table.
Are there others with these issues that have found comfortable solutions?
