bsinmich
May 08, 2015Explorer
In the past many have suggested using a relay to get higher voltage to the headlights. Use a larger wire to the relay to provide full voltage. You can check to see what your voltage is at the headlights with a simple VOM. 10 V will definitely give a dim light. I just sold my Mountain Aire last week that I had 11 years and never once needed the headlights.
