Bluedog's avatar
Bluedog
Winnebago Fiberglass Roof
In considering the purchase of a pre-owned Winnebago Class C with a fiberglass roof should there be a concern with cracking or separation due to twisting of the body over time?
  • Dakzuki wrote:
    Bumpyroad wrote:
    super_camper wrote:
    Bumpyroad wrote:
    crawford wrote:
    rubber roofs sucks in plain English more maintenance less rewards doing all the work and they will fail, stick with the winny's roof much better deal last a lot longer and less chance of leaks.
    x2
    as Beverley, or Ken sez. keep up the maintenance.
    bumpy
    This is bad advice. There are many types of roofing material that people lump into the rubber roof category so do some reading.
    Some roofing materials, like TPO, can last a very long time if maintained properly and the maintenance is no more difficult than on a fiberglass roof.
    a TPO roof is NOT the same as a rubber (EPDM) roof. so what is the "bad advice".?
    bumpy
    Correct. It has 3 letters in stead of 4. It is still a cheaper and not as good as fiberglass IMO.
    but TPO is more desirable than rubber (EPDM) IMHO.
    bumpy
  • Bumpyroad wrote:
    super_camper wrote:
    Bumpyroad wrote:
    x2
    bumpy
    bumpy
  • super_camper wrote:
    Bumpyroad wrote:
    x2
    bumpy
    bumpy
  • Bumpyroad wrote:
    x2
    bumpy
    x2
    bumpy
  • No problems with the fibreglass skin. Regularly check the sides where the roof skin goes into the extrusion on top of the sidewall. We found the first cracks in the adhesive after about 5 years. It was a fairly simple repair, scrape/clean out old adhesive and then put in the new, its a Manusbond sp?? adhesive caulk.
    Goes without saying, check all the caulking.
    Winnebago sealants.
    Beverley and Ken
  • rubber roofs sucks in plain English more maintenance less rewards doing all the work and they will fail, stick with the winny's roof much better deal last a lot longer and less chance of leaks.
