Old_Crows
Feb 28, 2015Explorer
Kannon, If I may.....suggest..
Sprinter park brakes have a quirk. When you set it the handle can fold down...kind of neat as it is out of the way. You can move it up and down easily. To release the brake you have to pull it up to the stop then firmly pull against the stop and press the button. If you did it right the red dash light will go off at the bottom of the travel.
To extend or retract the slide: In PARK; PB ON, engine running!
Last... Do NOT add an transmission cooler! Mother Benz has it all sorted out and you will not believe how complicated your life will become by messing with the engineering on a Mercedes. And expensive if you've jacked your warranty. Its fine just like it is.
Pay strict attention to Mother Benz's engine oil recommendation of 229.52 qualification.
Enjoy your RV!
Enjoy your RV!
