neschultz
Jul 20, 2014Explorer
Rkymtn - I had that same noise and at least a similar problem. When we first got our Via, I noticed that the top of our drivers door was not in as far (closed) as the bottom and was just about ready to take it in for service when I discovered that you need to almost slam the door to get it to close properly. Putting your hand high when you close it from outside....about the bottom of the window helps a lot. Since then I've noticed the same thing on every new one I've seen.
38,782 PostsLatest Activity: Aug 31, 2026
