turbojimmy
Dec 28, 2016Explorer
brianokeefe wrote:
some progress. I removed the unit and tried direct 12V input to the motor and it runs. I followed both red and black wires. Black goes somewhere besides the relay (I'll ck the diagram) and applying voltage to it all the way to the splice while connecting the red to power no farther than one side of the relay, the motor ran. On the other side of the relay the red is dead. From the relay the red goes to the breaker and I jumped that and nothing. So it seems the relay is bad, yes? I'd really appreciate some feedback before I buy and install a new one thought that's not much of an issue (I hope).
Many thanks again to all! Knowledge in numbers and knowledge is power!
See if you can get the pin-out of the relay. You would have a constant hot into the relay and a switched hot out. The relay is also going to have 12V constant for the switching mechanism, and is likely activated with a ground sent from the control board.
