cbeierl
Aug 30, 2013Explorer
For reference, here is the Winnebago Wiring Identification Guide and the Body, 12 Volt Wiring Diagram for your coach. (Btw, I find the best way to work with these diagrams is to print them out and then tape the pages together so that each 'sheet' is complete. Then it's much easier to trace the wires on the sheets with a highliter.)
Your three right side puck lamps show up in position A-9 and A-10 on SHEET 2 (page 10 of the pdf). They get their ground connection from wire JN and power from YS. Both of those go back to a 12-pin connector at position A-14 on SHEET 2 (still page 10 of the pdf). YS is on pin 9 of the connector which is physically located INSIDE the rear wall of the linen cabinet.
This plug this connects to is at position C-32 on SHEET 2 (page 8 of the pdf). From here YS goes to pin 8 of a 15-pin plug at position B-32 on the same sheet, physically located in the base of the cabinet behind the front right slide.
The plug this connects to is at position C-8 on SHEET 4 (pdf page 11). From this connector YS goes to the dinette overhead light switch shown at position D-4.5 on the same sheet. Returning from that switch is wire JG which returns to pin 7 on the same 15-pin plug and then continues to the 12V breaker panel at position D-20 on SHEET 2.
38,769 PostsLatest Activity: Mar 29, 2026
