cbeierl
Aug 31, 2013Explorer
phoenix.bears wrote:
You said one connection point is INSIDE the wall behind the linen closet, there is no access panel, why would they bury it like that? The second point is in "base of cabinet behind the right side slide". Can you give me a little more info on that location?...
Thanks again, for the help.
Actually, I'm just reading from the diagrams. I added the 'INSIDE' because I'm assuming that they wouldn't leave the wires exposed inside a cabinet. A call to Winnebago should be able to identify how that plug might be accessed.
The suggestion on the post above this one to start with the fixtures makes a lot of sense.
On Edit: BTW, the diagrams print well on 8.5x11" paper which can then be taped together to form the whole sheet.
38,769 PostsLatest Activity: Mar 28, 2026
