23hotrodr's avatar
23hotrodr
Winnebago with padded foam headliner?
Did Winnebago improve the foam backed vinyl headliner for 2007 era MHs, or should I expect to have it start falling down like much earlier versions of this headliner? I know it is the foam that disintegrates on much earlier years and was wondering if they improved the foam at all to prevent the dreaded ceiling droop.
Thanks-- Mick
  • Sounds like they have improved the foam on the vinyl padded headliners. I did see a 2007 Sun Cruiser with only 22,000 miles on it with about an 8" area near the couch that was loose. The headliners that are carpet glued directly to the ceiling don't seem to have the problem. The problem has always been with the foam rubber underneath the vinyl disintegrating on much earlier models. Just concerned whether they have solved this issue with 2007 vintage models.
  • On our 06 Outlook, the finish is a carpet like material laminated to the luan, then foam insulation. No problems in ours.
    Ken
  • No ceiling droop on a 1999 Adventurer with over 104,000 miles.
  • owned a 2008 Voyage never had a problem - actually never heard of a problem before until your post and I hang out all the time on the Winnebago owner forum on IV2
