Itasca55's avatar
Itasca55
Winnobago horror in the hiding spots . wires.
If you have any 90s winnobago you really need to take the time and look in cabinet behind the power125v and 12v contol panel
I was looking at wiring for furnace and spotted 2 125v wires pinched super tight against the steel of control panel back and the 1/2 plywood that holds the furnance. I was horrified. I need to un screw the main panel to slide it out a bit and check wires and make clearance for the 2 wires . Huge job . It's all original in there straight from the factory in 1992. Has others spotted stuff like this ? I have pictures of it there in there dam tight to point the 1/2 plywoods flexing . How I know it's original is neather the control panel or furnance wasnever beenremoved. It's a model 27RC rear bath. It's hard to see I stuck cellphone cam up there and snapped picture to make it out.
Itasca55
  • If you do much reading on the forum, you will realize quality is not Job #1 in the RV industry.
  • It's an RV, things like that are normal. Tanks falling out on the highway or even while people are sleeping, water lines blowing apart, wire connections falling apart and on and on are all normal.
