JaxDad wrote:
gutfelt wrote:
pianotuna wrote:
charge them. disconnect the positive posts. reconnect in spring or first trip.
times 2 exactly what to do
matter not what cable u remove + or -
If the battery is dead in the spring then replace it as its weak
no way a good fully charged battery should go dead after sitting 4 months or 6 months that has zero draw(disconnected)
Disconnecting the positives is far more dangerous than disconnecting the negatives.
If the wrench touches any metal that is a ground bad things happen when you’re working on the positive terminals.
If however you are working on the negative side and the wrench touches a ground........ nothing happens.
LOL well I guess if ones so stupid that they don't know any better and somehow his wrench somehow grounds out while removing or installing the cable anything is possible
my point was and is its best to remove a cable so theres zero chance of a power draw
