WesternHorizon's avatar
Jan 31, 2016
Winter boondocking in a Class C
My class C is winterized about 4 months out of the year, but I use it year-round. A few notes.
I always use paper plates and bowls, so dishwashing is never an issue.
For metal cutlery, I have a tupperware filled with rubbing alcohol. As I drive the cutlery soaks in the alcohol. Take it out, dry it off, use it.
Water is carried in a dozen 1 gallon jugs. They never seem to freeze. Refills at WaterMill or Glacier water stands, which can be found at Wal-Marts and Dollar stores.
For number 1, a heavy gallon jug with cap. For those of the female configuration, a “feminine funnel” is helpful. Avoid confusing this special jug with beverage containers.
For number 2, two plastic garbage bags in the toilet with the seat holding them in place.
For cleanup and sponge baths, baby wipes work great. I just buy a case of Costco baby wipes.
I use a winter sleeping bag, and set the thermostat to 50 degrees. Otherwise it takes a long time to warm up the RV in the morning, and condensation on the windows can be a problem.
The windows in the cabover area leak cold air. I’ve covered these with a plastic storm window kit, the kind with adhesive tape.
Between trips, I have a BatteryMINDer Charger/Maintainer/Desulfater Model# 2012 on the house battery and another on the chassis battery. These are expensive chargers but they have temperature compensation and they desulfate the batteries.
Compared to winter tent camping, even a winterized RV is luxurious. Not sure I would do this in the northern reaches of the US or in Canada where it gets seriously cold but it has been working great for me down into the teens overnight.
Other winter boondocking experiences and tips?
(Finally got this post to work on 2/5/16. Sorry for the delay.)
  • Have you fixed the roof yet?! I know you where really doing a complete remodel. Looks like quite a project. :C
  • It very much depends on where you plan to boon dock. S CA and NM have very different winters.
  • We do it all the time, I put some antifreeze, the one used for the potable system in my grey and black tanks since they are out side this keeps the discharge valves and goodies from completely freezing, that way I can transfer the goods with the blue tote to the dump station, have one AGM marine battery and a solar panel, we also use oil lamps at night they provide light and some heat, this saves the battery for the furnace blower, and I have installed small LED lamps in the over head of the cabinets and in the kitchen and bathroom, also out side and on the steps, they are more than enough out in the boonies, give it a try we have been totally alone in National and State parks for days.
    navegator
  • A four seasons RV with enclosed heated tanks and valves.
    You will need lots of propane, a large battery bank, and a way to recharge quickly. A temperature compensated charge controller would be good, too.
  • Tripalot wrote:
    So, what is special about that? It is probably standard practice for most when water hookups are not available.
    Nothing is special about it at all. Thanks for your feedback.
  • So, what is special about that? It is probably standard practice for most when water hookups are not available.
