flyboykuao
Oct 23, 2018Explorer
Winter heat
Hello, I am a newer RV owner. I'd like to keep the unit heated at a minimum heat this winter (near 50 F). I can think of 2 choices: Use a space heater or plug the RV into electricity and then use i...
flyboykuao wrote:
Hello, I am a newer RV owner. I'd like to keep the unit heated at a minimum heat this winter (near 50 F). I can think of 2 choices: Use a space heater or plug the RV into electricity and then use it's furnace. Can someone please recommend which is better?
If the furnace is your choice - can you tell me if a 110v extension cord plugged from a typical house sock to the RV will supply enough power? I am unfamiliar with electricity and amps - so I am unable to make sense of the furnace specs.
Thanks in advance.
