Hello, I am a newer RV owner. I'd like to keep the unit heated at a minimum heat this winter (near 50 F). I can think of 2 choices: Use a space heater or plug the RV into electricity and then use i...
If you need help in winterizing, you may want to do a search or start a new thread.
As to heat, if you are winterizing, you are going to have 110 and stored at home, I would do a small ceramic heat cube. That would take the moisture out.
if you are winterizing and it is at another facility, use Dry Z Air, Damprid or H2Out.
