flyboykuao
Oct 23, 2018Explorer
Winter heat
Hello, I am a newer RV owner. I'd like to keep the unit heated at a minimum heat this winter (near 50 F). I can think of 2 choices: Use a space heater or plug the RV into electricity and then use i...
way2roll wrote:Busskipper wrote:
if reflexit is installed correctly then my history in Maryland is it seldom gets below 40 degrees, in 12 years only 30 degrees once - Just my experience in my Coach.
Best of Luck,
I think that depends on where in MD. We lived on top of the mountain and it wasn't uncommon to wake up to 0 or even negative temps in Jan and Feb.
To the OP - as others have stated, understanding why you want to achieve a certain temp and what means of heat you have are things needed to know. I would agree that a small heater set to 35-36 with a temp monitor in the coach as well as the wet bays would be a start. But is there a reason you want it heated all winter? Otherwise 10 minutes to drain the lines and fill with RV antifreeze allows you forgo any heat source and mitigate worry about anything freezing.
As for the lightbulb, I think that's referred to for wet bays only. Not an application to keep the entire coach above freezing.
A light bulb on a thermocube plug is cheap and easy.
