flyboykuao's avatar
flyboykuao
Winter heat
Hello, I am a newer RV owner. I'd like to keep the unit heated at a minimum heat this winter (near 50 F). I can think of 2 choices: Use a space heater or plug the RV into electricity and then use it's furnace. Can someone please recommend which is better?
If the furnace is your choice - can you tell me if a 110v extension cord plugged from a typical house sock to the RV will supply enough power? I am unfamiliar with electricity and amps - so I am unable to make sense of the furnace specs.
Thanks in advance.
  • Does your RV heater warm the tanks? An electric heater in the living area will not.
  • I would use a milk barn style 120 volt electric heater. Many have two wattage settings. I run mine on the lower one.
    On on board furnace will eat up the propane.
  • I've read where RV'ers have used a light bulb to maintain heat in the RV during the winter months. Not sure how well it works but I remember reading several posts over the years with reference to using a light bulb. Now days it's becoming harder to find an incandescent light bulb to use for the heat source.
  • Propane furnace will work best.
    Extension cord will be ok.
    Call me if you wish.
